40-195 Crackly Sound
Does it make the noise just after turning on the set say for 5 minutes or still making noise after 30 minutes? Like other have said cold solder joint sometimes using Deoxit on Q-tip clean all parts of tube sockets and base of all tubes. Dampness can also be a problem that will go away after about 30-45 minutes. David
40-195 Crackly Sound - by dfields69 - 11-23-2014, 12:07 PM
RE: 40-195 Crackly Sound - by Jeremy S - 11-24-2014, 10:36 AM
RE: 40-195 Crackly Sound - by Jeremy S - 11-24-2014, 01:56 PM
RE: 40-195 Crackly Sound - by dfields69 - 11-25-2014, 06:30 PM
RE: 40-195 Crackly Sound - by David - 11-25-2014, 03:29 PM
RE: 40-195 Crackly Sound - by dfields69 - 11-25-2014, 06:34 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7176 online users. [Complete List]
» 1 Member(s) | 7175 Guest(s)
