New to Phorum and a Philco 38
Hi Arran, thanks for your reply. I agree also, it is much better to use a battery eliminator for a DC set than to convert it to AC.
It looks like the type 6 ballast tube socket was there, I can see that the rivets were ground out. If I am understanding things, a 38 would have had the socket, but a jumper would have been placed across the filament contacts. Does that sound right?
Given what you see here, do you think a restoration back to DC is reasonable?
I think my first plan should be to use the schematic to create a point to point wiring diagram, and secondly to see if I can even locate the proper sockets.
Russ
New to Phorum and a Philco 38 - by radioalfa - 11-22-2014, 11:49 PM
RE: New to Phorum and a Philco 38 - by sam - 11-23-2014, 02:19 AM
RE: New to Phorum and a Philco 38 - by Arran - 11-23-2014, 05:14 AM
RE: New to Phorum and a Philco 38 - by morzh - 11-23-2014, 11:24 AM
RE: New to Phorum and a Philco 38 - by klondike98 - 11-23-2014, 11:35 AM
RE: New to Phorum and a Philco 38 - by radioalfa - 11-23-2014, 12:57 PM
RE: New to Phorum and a Philco 38 - by radioalfa - 11-24-2014, 11:04 PM
RE: New to Phorum and a Philco 38 - by Arran - 11-25-2014, 04:38 AM
RE: New to Phorum and a Philco 38 - by radioalfa - 11-25-2014, 11:28 PM
RE: New to Phorum and a Philco 38 - by Arran - 11-26-2014, 02:00 AM
RE: New to Phorum and a Philco 38 - by radioalfa - 11-26-2014, 09:15 AM
There are currently 6496 online users. [Complete List]
» 2 Member(s) | 6494 Guest(s)
