My new A52CK
Kirk;
  I knew what it would be like the first time you posted a link to that auction, a typical "antique mall" style restoration, or what I call a "strip n' clearcoat" job, there are a few of those sorts of radios on my nearby craigslist sites. If you know what to look for it's very difficult for them to hide, no toners, a flat lifeless look, pits from open grain.
My new A52CK - by OldRestorer - 11-26-2014, 10:02 PM
RE: My new A52CK - by KCMike - 11-26-2014, 10:26 PM
RE: My new A52CK - by Arran - 11-27-2014, 12:53 AM
RE: My new A52CK - by JimZ - 11-27-2014, 10:55 AM
RE: My new A52CK - by OldRestorer - 11-27-2014, 11:02 AM
There are currently 7455 online users. [Complete List]
» 2 Member(s) | 7453 Guest(s)
