How to re-center speaker cone
Anyone know a good way to re-center cone to voice coil?
I have one that is rubbing and causing distortion at low volume.
Don't want to re-cone as the cone is in good shape.
murf
[Image: http://i1161.photobucket.com/albums/q509...rtone2.jpg]
[Image: http://i1161.photobucket.com/albums/q509...rtone3.jpg]
How to re-center speaker cone - by murf - 11-27-2014, 04:34 PM
RE: How to re-center speaker cone - by morzh - 11-28-2014, 12:25 PM
RE: How to re-center speaker cone - by murf - 11-30-2014, 11:25 AM
RE: How to re-center speaker cone - by codefox1 - 12-02-2014, 03:37 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
