hi new to phorum
Welcome. Looks to be a nice enough radio maybe from 50's.
Check the rear dust cover for any numbers or perhaps inside the case and maybe you can
find the model here
http://www.radiomuseum.org/m/philco_gb_en_1.html
Looking quickly at sold British Philco on the Ebay there I couldn't find an exact match so maybe a rear picture will help someone here familiar with the chassis
hi new to phorum - by Fienulla fairylocks - 11-27-2014, 01:14 PM
RE: hi new to phorum - by Fienulla fairylocks - 11-27-2014, 05:43 PM
RE: hi new to phorum - by JimZ - 11-27-2014, 06:03 PM
RE: hi new to phorum - by Fienulla fairylocks - 11-27-2014, 06:31 PM
RE: hi new to phorum - by Ron Ramirez - 11-27-2014, 07:04 PM
RE: hi new to phorum - by Fienulla fairylocks - 11-27-2014, 08:45 PM
RE: hi new to phorum - by Arran - 11-29-2014, 02:05 AM
RE: hi new to phorum - by Radioroslyn - 11-30-2014, 02:30 PM
hi new to phorum - by sam - 11-27-2014, 02:42 PM
RE: hi new to phorum - by Fienulla fairylocks - 11-27-2014, 05:42 PM
There are currently 2210 online users. [Complete List]
» 1 Member(s) | 2209 Guest(s)
