Grill Cloth Cardboard Backing
Joe--How did you cut the wall panel to the shape of your grille cloth mounting board? I found a "Tempered Harboard 1/8 in. x 2 ft. x 4 ft" project panel available through Home Depot for $5.97. I was searching under MDF and also under Masonite. Would this work? I suspect it's too hard to use an Exacto knife or similar. Would one use a manual coping saw, or what would be your best suggestion? Here is my broken backing board, and a sample of the deteriorated grille cloth with the amazing metallic copper sheen which doesn't show in the photograph.
Grill Cloth Cardboard Backing - by Joeztech - 12-18-2013, 07:55 AM
RE: Grill Cloth Cardboard Backing - by Eliot Ness - 12-18-2013, 09:19 AM
RE: Grill Cloth Cardboard Backing - by Joeztech - 12-18-2013, 03:08 PM
RE: Grill Cloth Cardboard Backing - by Joeztech - 12-23-2013, 08:18 PM
RE: Grill Cloth Cardboard Backing - by Joeztech - 01-01-2014, 07:57 AM
RE: Grill Cloth Cardboard Backing - by jhgrahamjr - 11-28-2014, 02:01 PM
RE: Grill Cloth Cardboard Backing - by tab10672 - 11-28-2014, 04:43 PM
RE: Grill Cloth Cardboard Backing - by JimZ - 11-29-2014, 10:45 AM
There are currently 4473 online users. [Complete List]
» 1 Member(s) | 4472 Guest(s)
