CLEANING PHILCO 43 DIAL
You could possibly try some mineral spirit, just start in some inconspiuous place, see if it is benign.
I also use Windex and never needed anything else.
CLEANING PHILCO 43 DIAL - by jhgrahamjr - 11-28-2014, 05:26 PM
RE: CLEANING PHILCO 43 DIAL - by morzh - 11-28-2014, 05:34 PM
RE: CLEANING PHILCO 43 DIAL - by jhgrahamjr - 11-28-2014, 05:47 PM
RE: CLEANING PHILCO 43 DIAL - by Eric Adams - 11-28-2014, 06:14 PM
RE: CLEANING PHILCO 43 DIAL - by jhgrahamjr - 11-28-2014, 06:21 PM
RE: CLEANING PHILCO 43 DIAL - by Eric Adams - 11-28-2014, 06:33 PM
RE: CLEANING PHILCO 43 DIAL - by jhgrahamjr - 11-29-2014, 06:16 PM
RE: CLEANING PHILCO 43 DIAL - by Eric Adams - 11-30-2014, 01:14 PM
RE: CLEANING PHILCO 43 DIAL - by jhgrahamjr - 12-05-2014, 03:05 AM
RE: CLEANING PHILCO 43 DIAL - by Eric Adams - 12-05-2014, 10:51 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7093 online users. [Complete List]
» 1 Member(s) | 7092 Guest(s)
