Atwater Kent 55C - she's singing again
Well, don't start digging.
You can heat the thing up just till it gets soft. As I recall the cap is fairly large. That is about all I remember except that it would be easy to miss and bad to do so since it is across the OP primary. The last one, I think I did with a heat gun. It was about 6 months ago or about 5 months 3 weeks and 5 days too long.
You know it would probably work just as well if you were able to disconnect 1 leg of the old cap - if all else seems impossible.
RE: Atwater Kent 55C in Kiel Table - by sam - 11-25-2014, 01:17 PM
RE: Atwater Kent 55C in Kiel Table - by KCMike - 11-25-2014, 04:51 PM
RE: Atwater Kent 55C in Kiel Table - by Jayce - 11-26-2014, 02:03 PM
RE: Atwater Kent 55C in Kiel Table - by radioalfa - 11-26-2014, 11:05 PM
RE: Atwater Kent 55C in Kiel Table - by Phlogiston - 11-28-2014, 11:08 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
