hi new to phorum
  From what I can tell about other British Philco models from the same era, it likely used North American style tubes/valves, and since it was a Philco they used a lot of Loctals. Loctal tubes are those shorter cylindrical shaped tubes/valves with a metal base, and eight short pins, they were developed by Sylvania in the late 1930s and were fairly popular up until the early 1950s. This is a good thing if you need to replace any, tube designs were standardized fairly early on in North America, even if they used different bases most AC tubes used a filament voltage of 6.3 volts, some British valves not only used odd bases but odd voltages like 4 volts. On thing to keep an eye on is the rectifier tube, if it's a 6X5GT, usually it's not an issue but sometimes the manufacturers ignored the maximum specifications of that tube and ran it to it's limits.
  Your Philco has the typical styling of a British made wooden table set made in the late 1940s through mid 1950s, a fairly plain plywood box, mesh grille, and a white plastic escutcheon. Without the name "Philco" on the dial glass it could be mistaken for a Pye, a Murphy, an Ekco, or a wooden Bush radio from the same period. They all remind me of the speaker cabinets they used to use for public address systems in schools and hospitals.
hi new to phorum - by Fienulla fairylocks - 11-27-2014, 01:14 PM
RE: hi new to phorum - by Fienulla fairylocks - 11-27-2014, 05:43 PM
RE: hi new to phorum - by JimZ - 11-27-2014, 06:03 PM
RE: hi new to phorum - by Fienulla fairylocks - 11-27-2014, 06:31 PM
RE: hi new to phorum - by Ron Ramirez - 11-27-2014, 07:04 PM
RE: hi new to phorum - by Fienulla fairylocks - 11-27-2014, 08:45 PM
RE: hi new to phorum - by Arran - 11-29-2014, 02:05 AM
RE: hi new to phorum - by Radioroslyn - 11-30-2014, 02:30 PM
hi new to phorum - by sam - 11-27-2014, 02:42 PM
RE: hi new to phorum - by Fienulla fairylocks - 11-27-2014, 05:42 PM
There are currently 3858 online users. [Complete List]
» 1 Member(s) | 3857 Guest(s)
