Simplex Radio - Speaker
I have found an old, 1932-34, Simplex cathedral radio. Simplex was based in Sanduskey Ohio and was bought by Philco in 1937 I believe. The most obvious issue is that it does not have a speaker. I understand that the speakers of this era have both a field coil and a voice coil. Will a Philco speaker from the same vintage work? Are such available? I have a schematic of the Simplex. I have heard of some modern workarounds, but I think I would prefer to get an old replacement if it would work. Any thoughts?
Thanks
Simplex Radio - Speaker - by Guest - 11-22-2008, 03:25 PM
Re: Simplex Radio - Speaker - by 7estatdef - 05-02-2011, 06:45 PM
