CLEANING PHILCO 43 DIAL
I've used it on plastic dial covers from the 40s with no issues. It was designed to clean plastic headlight covers on cars.
Eric
The Villages, FL
CLEANING PHILCO 43 DIAL - by jhgrahamjr - 11-28-2014, 05:26 PM
RE: CLEANING PHILCO 43 DIAL - by morzh - 11-28-2014, 05:34 PM
RE: CLEANING PHILCO 43 DIAL - by jhgrahamjr - 11-28-2014, 05:47 PM
RE: CLEANING PHILCO 43 DIAL - by Eric Adams - 11-28-2014, 06:14 PM
RE: CLEANING PHILCO 43 DIAL - by jhgrahamjr - 11-28-2014, 06:21 PM
RE: CLEANING PHILCO 43 DIAL - by Eric Adams - 11-28-2014, 06:33 PM
RE: CLEANING PHILCO 43 DIAL - by jhgrahamjr - 11-29-2014, 06:16 PM
RE: CLEANING PHILCO 43 DIAL - by Eric Adams - 11-30-2014, 01:14 PM
RE: CLEANING PHILCO 43 DIAL - by jhgrahamjr - 12-05-2014, 03:05 AM
RE: CLEANING PHILCO 43 DIAL - by Eric Adams - 12-05-2014, 10:51 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
