  • 1 Vote(s) - 5 Average
New here, an 89B I'm repairing
By all means, upgrade the 36 tube to a 77 tube. It's pretty much the same circuit as the earlier version, the Model 19. The phenolic tube sockets are a source of nasty intermittents; if you can, replace those sockets; cleaning, pinching, and polishing them didn't do anything. .
With new sockets and the 77 upgrade, I've got a super radio that's a true "keeper"
Pete AI2V
New here, an 89B I'm repairing - by sparkydave - 06-20-2014, 08:45 PM
RE: New here, an 89B I'm repairing - by Mondial - 06-20-2014, 09:47 PM
RE: New here, an 89B I'm repairing - by gregb - 06-20-2014, 09:49 PM
RE: New here, an 89B I'm repairing - by morzh - 12-01-2014, 04:38 PM
RE: New here, an 89B I'm repairing - by AI2V - 12-01-2014, 06:12 PM
There are currently 4530 online users. [Complete List]
» 2 Member(s) | 4528 Guest(s)
