37-675 Dial
Jo
I am a bit slow today....WHERE do you get "sharp thin bright light (pointer)? WHAT is the surface you see it on?
I mean, unless the lens projects it on something, there will be no thin pointer.
If it is not the dial disk you see it on, what then?
37-675 Dial - by w4rtc - 11-24-2014, 06:35 PM
RE: 37-675 Dial - by morzh - 11-24-2014, 09:37 PM
RE: 37-675 Dial - by AI2V - 12-01-2014, 05:56 PM
RE: 37-675 Dial - by morzh - 12-01-2014, 06:57 PM
RE: 37-675 Dial - by w4rtc - 12-01-2014, 10:32 PM
RE: 37-675 Dial - by morzh - 12-02-2014, 12:48 AM
RE: 37-675 Dial - by w4rtc - 12-02-2014, 01:33 AM
RE: 37-675 Dial - by morzh - 12-02-2014, 10:51 AM
RE: 37-675 Dial - by morzh - 12-02-2014, 10:40 PM
RE: 37-675 Dial - by Ron Ramirez - 12-02-2014, 11:02 PM
RE: 37-675 Dial - by AI2V - 12-06-2014, 05:46 PM
RE: 37-675 Dial - by w4rtc - 12-06-2014, 09:19 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3058 online users. [Complete List]
» 1 Member(s) | 3057 Guest(s)
