Philco Canada 51A
 Those pushbuttons look familiar, I think that they may have used a similar style on some pieces of test equipment.
Philco Canada 51A - by Ron Ramirez - 11-25-2014, 10:39 PM
RE: Philco Canada 51A - by Ron Ramirez - 11-25-2014, 10:47 PM
RE: Philco Canada 51A - by Arran - 11-27-2014, 02:13 AM
RE: Philco Canada 51A - by Ron Ramirez - 11-28-2014, 11:49 PM
RE: Philco Canada 51A - by Arran - 11-29-2014, 05:04 AM
RE: Philco Canada 51A - by Jeremy S - 11-26-2014, 08:25 AM
RE: Philco Canada 51A - by KCMike - 11-26-2014, 10:23 AM
RE: Philco Canada 51A - by Eliot Ness - 11-27-2014, 02:35 AM
RE: Philco Canada 51A - by Ron Ramirez - 11-26-2014, 12:58 PM
RE: Philco Canada 51A - by Ron Ramirez - 11-26-2014, 11:10 PM
RE: Philco Canada 51A - by tom.seeger - 11-27-2014, 05:11 PM
RE: Philco Canada 51A - by Ron Ramirez - 11-28-2014, 10:35 PM
RE: Philco Canada 51A - by radiohenry - 11-29-2014, 08:41 AM
RE: Philco Canada 51A - by Ron Ramirez - 11-29-2014, 05:36 PM
RE: Philco Canada 51A - by Arran - 11-30-2014, 01:40 AM
RE: Philco Canada 51A - by Paul Philco322 - 11-29-2014, 07:52 PM
RE: Philco Canada 51A - by Ron Ramirez - 11-29-2014, 10:37 PM
RE: Philco Canada 51A - by Ron Ramirez - 11-30-2014, 12:34 PM
RE: Philco Canada 51A - by Ron Ramirez - 11-30-2014, 07:30 PM
RE: Philco Canada 51A - by NostalgiaRadioTime - 11-30-2014, 11:45 PM
RE: Philco Canada 51A - by Jeremy S - 12-02-2014, 08:30 AM
RE: Philco Canada 51A - by Arran - 12-02-2014, 03:01 PM
RE: Philco Canada 51A - by GarySP - 12-02-2014, 06:21 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6644 online users. [Complete List]
» 1 Member(s) | 6643 Guest(s)
