37-675 Dial
Joe
I wish my iPad made photos I could post here.
In short, the figures on the dial are BARELY lighted, the line is bright but the narrow column lighting numbers is extremely faint.
The dial's background is lighted itself, and so the extra lighting has to be discerned on already lighted disk, and it is very little difference. So it is possible yours is working as designed.
37-675 Dial - by w4rtc - 11-24-2014, 06:35 PM
RE: 37-675 Dial - by morzh - 11-24-2014, 09:37 PM
RE: 37-675 Dial - by AI2V - 12-01-2014, 05:56 PM
RE: 37-675 Dial - by morzh - 12-01-2014, 06:57 PM
RE: 37-675 Dial - by w4rtc - 12-01-2014, 10:32 PM
RE: 37-675 Dial - by morzh - 12-02-2014, 12:48 AM
RE: 37-675 Dial - by w4rtc - 12-02-2014, 01:33 AM
RE: 37-675 Dial - by morzh - 12-02-2014, 10:51 AM
RE: 37-675 Dial - by morzh - 12-02-2014, 10:40 PM
RE: 37-675 Dial - by Ron Ramirez - 12-02-2014, 11:02 PM
RE: 37-675 Dial - by AI2V - 12-06-2014, 05:46 PM
RE: 37-675 Dial - by w4rtc - 12-06-2014, 09:19 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4002 online users. [Complete List]
» 1 Member(s) | 4001 Guest(s)
