42-1012 question
Hi
A good source for the buttons and knobs is Old-Time Replications.
http://www.antiqueradioknobs.com/
As for the escutcheon, I'm afraid you are out of luck. No one reproduces that escutcheon, and it is highly unlikely that anyone ever will. It simply isn't in enough demand for anyone to justify reproducing it.
42-1012 question - by Guest - 11-23-2008, 11:18 PM
Re: 42-1012 question - by Ron Ramirez - 11-24-2008, 10:04 PM
Re: 42-1012 question - by Guest - 11-24-2008, 10:43 PM
Re: 42-1012 question - by Ron Ramirez - 11-24-2008, 11:24 PM
There are currently 11054 online users. [Complete List]
» 2 Member(s) | 11052 Guest(s)
