PHILCO 80 JUNIOR
In the original state of the radio was the cable that makes the modification for amplification from the 1st valve to the central terminal of the volume. When reassembling the new wiring I've respected.
I note that the reception is very low and decided to check the wiring. I find that the connection is made in the second coil (No.1 picture) when it should be on point number two.
Should I change the connection?, Or the result will be the same?.
[Image: http://s27.postimg.org/7o79ti72r/185.jpg]
PHILCO 80 JUNIOR - by Pillo69 - 11-30-2014, 04:41 PM
RE: PHILCO 80 JUNIOR - by morzh - 11-30-2014, 04:49 PM
RE: PHILCO 80 JUNIOR - by klondike98 - 11-30-2014, 05:32 PM
RE: PHILCO 80 JUNIOR - by Pillo69 - 11-30-2014, 07:21 PM
RE: PHILCO 80 JUNIOR - by Pillo69 - 12-04-2014, 09:04 AM
RE: PHILCO 80 JUNIOR - by KCMike - 12-04-2014, 11:09 AM
RE: PHILCO 80 JUNIOR - by thirtiesradio - 12-12-2014, 03:07 AM
RE: PHILCO 80 JUNIOR - by Radioroslyn - 12-12-2014, 10:52 AM
RE: PHILCO 80 JUNIOR - by Pillo69 - 12-13-2014, 05:07 PM
RE: PHILCO 80 JUNIOR - by mikethedruid - 12-18-2014, 06:48 PM
There are currently 5296 online users. [Complete List]
» 5 Member(s) | 5291 Guest(s)
AvatarAvatarAvatarAvatar
