I FOUND THE HUM ON MY PHILCO 90!!
My Congrats as well.
This sounds more like a weird case of speaker rattle, excuse the pun.
Hum is normally of electrical origin.
Always new things to learn.
Richard
I FOUND THE HUM ON MY PHILCO 90!! - by Guest - 11-24-2008, 01:40 PM
Re: I FOUND THE HUM ON MY PHILCO 90!! - by rghines1 - 11-26-2008, 05:06 PM
There are currently 10438 online users. [Complete List]
» 2 Member(s) | 10436 Guest(s)
