37-675 Dial
If you have a replacement dial, that is easily the problem. The replacements are much denser than the originals. Originals are kind of a light orange in color and the new replacements are thick and brown in color.
The LED's that Ron recommends are great! Even so they aren't the best for a sharp dial "line".
Pete AI2V
37-675 Dial - by w4rtc - 11-24-2014, 06:35 PM
RE: 37-675 Dial - by morzh - 11-24-2014, 09:37 PM
RE: 37-675 Dial - by AI2V - 12-01-2014, 05:56 PM
RE: 37-675 Dial - by morzh - 12-01-2014, 06:57 PM
RE: 37-675 Dial - by w4rtc - 12-01-2014, 10:32 PM
RE: 37-675 Dial - by morzh - 12-02-2014, 12:48 AM
RE: 37-675 Dial - by w4rtc - 12-02-2014, 01:33 AM
RE: 37-675 Dial - by morzh - 12-02-2014, 10:51 AM
RE: 37-675 Dial - by morzh - 12-02-2014, 10:40 PM
RE: 37-675 Dial - by Ron Ramirez - 12-02-2014, 11:02 PM
RE: 37-675 Dial - by AI2V - 12-06-2014, 05:46 PM
RE: 37-675 Dial - by w4rtc - 12-06-2014, 09:19 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3463 online users. [Complete List]
» 1 Member(s) | 3462 Guest(s)
