Philco 116 versus 116B
Evening Gentlemen,
I recently purchased a model 116. I am able to locate a schematic for a 1116B in my riders and as well as Nostalgia air. However their seems to be some marked differences.
Where can I get my hands on a model 116 schematic?? I am willing to throw a few bucks at it if needed.
Dave
Philco 116 versus 116B - by Dave Slusarczyk - 11-27-2008, 01:29 AM
Re: Philco 116 versus 116B - by Ron Ramirez - 11-27-2008, 08:19 AM
Re: Philco 116 versus 116B - by Dave Slusarczyk - 11-27-2008, 12:24 PM
Re: Philco 116 versus 116B - by Chuck Schwark - 11-28-2008, 12:17 AM
Re: Philco 116 versus 116B - by Dave Slusarczyk - 11-28-2008, 01:07 AM
Re: Philco 116 versus 116B - by BDM - 11-28-2008, 03:35 PM
Re: Philco 116 versus 116B - by etech - 11-30-2008, 11:11 AM
Re: Philco 116 versus 116B - by Ron Ramirez - 11-30-2008, 11:39 AM
Re: Philco 116 versus 116B - by Dave Slusarczyk - 11-30-2008, 02:37 PM
Re: Philco 116 versus 116B - by Ron Ramirez - 11-30-2008, 04:18 PM
Re: Philco 116 versus 116B - by etech - 11-30-2008, 06:54 PM
