42-1003 code 121 bol
The Model 42-1002 looks identical, except for the skinny
crystal pickup tonearm.
Chuck
42-1003 code 121 bol - by mountain man - 12-08-2014, 09:18 AM
RE: 42-1003 code 121 bol - by Chuck Schwark - 12-08-2014, 10:12 AM
RE: 42-1003 code 121 bol - by sam - 12-08-2014, 02:34 PM
RE: 42-1003 code 121 bol - by mountain man - 12-08-2014, 05:05 PM
RE: 42-1003 code 121 bol - by sam - 12-09-2014, 02:59 PM
RE: 42-1003 code 121 bol - by mountain man - 12-09-2014, 03:45 PM
RE: 42-1003 code 121 bol - by mountain man - 12-09-2014, 03:46 PM
RE: 42-1003 code 121 bol - by sam - 12-09-2014, 08:00 PM
RE: 42-1003 code 121 bol - by Chuck Schwark - 12-10-2014, 11:14 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6974 online users. [Complete List]
» 1 Member(s) | 6973 Guest(s)
