Noise in the a/c line
Ok here it goes, When I played it at home, the radio played great. When it was moved to country, the radio now has a lot of line noise.
So I would assume it would be coming from the outlet as line noise. Icon_neutral
Noise in the a/c line - by Robert - 11-26-2008, 11:52 PM
Re: Noise in the a/c line - by rghines1 - 11-27-2008, 11:04 AM
Re: Noise in the a/c line - by Robert - 11-27-2008, 11:56 AM
Re: Noise in the a/c line - by rghines1 - 11-27-2008, 05:41 PM
Re: Noise in the a/c line - by radiomikee - 11-28-2008, 09:39 AM
Re: Noise in the a/c line - by Robert - 11-28-2008, 07:55 PM
Re: Noise in the a/c line - by exray - 11-28-2008, 08:11 PM
Re: Noise in the a/c line - by Robert - 11-29-2008, 09:32 AM
Re: Noise in the a/c line - by exray - 11-29-2008, 09:41 AM
Re: Noise in the a/c line - by Robert - 11-29-2008, 09:53 AM
Re: Noise in the a/c line - by radiomikee - 12-04-2008, 01:37 PM
Re: Noise in the a/c line - by radiomikee - 12-04-2008, 01:44 PM
Re: Noise in the a/c line - by DeckApe - 12-04-2008, 02:35 PM
Re: Noise in the a/c line - by Texasrocker - 12-07-2008, 01:37 AM
Re: Noise in the a/c line - by DeckApe - 12-07-2008, 12:03 PM
Re: Noise in the a/c line - by codefox1 - 12-12-2008, 11:15 AM
Re: Noise in the a/c line - by Robert - 12-13-2008, 11:06 AM
Re: Noise in the a/c line - by radiomikee - 12-15-2008, 02:01 PM
Re: Noise in the a/c line - by exray - 12-16-2008, 10:24 AM
There are currently 10808 online users. [Complete List]
» 2 Member(s) | 10806 Guest(s)
