Removing wax from chassis
Xylene, is a great solvent for wax.
Keith
Removing wax from chassis - by 37silverstreak - 11-29-2014, 11:05 PM
RE: Removing wax from chassis - by morzh - 11-29-2014, 11:14 PM
RE: Removing wax from chassis - by Arran - 11-30-2014, 01:28 AM
RE: Removing wax from chassis - by radiohenry - 12-05-2014, 05:53 PM
RE: Removing wax from chassis - by keith49vj3 - 12-09-2014, 10:05 PM
RE: Removing wax from chassis - by Ron Ramirez - 12-09-2014, 10:17 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
