Removing wax from chassis
I just went though this. I had never reinstalled my 19B chassis in the cabinet which I refinished two years ago. The chassis was partially covered in wax from a power transformer meltdown. Amazingly, the original transformer was still good...but I digress.
I first tried denatured alcohol. It barely touched the stuff.
I did not have any lacquer thinner, so I then tried mineral spirits. That did a very good job of cleaning off the mess. Icon_thumbup
Removing wax from chassis - by 37silverstreak - 11-29-2014, 11:05 PM
RE: Removing wax from chassis - by morzh - 11-29-2014, 11:14 PM
RE: Removing wax from chassis - by Arran - 11-30-2014, 01:28 AM
RE: Removing wax from chassis - by radiohenry - 12-05-2014, 05:53 PM
RE: Removing wax from chassis - by keith49vj3 - 12-09-2014, 10:05 PM
RE: Removing wax from chassis - by Ron Ramirez - 12-09-2014, 10:17 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
