0.00011 mf caps in bakelite blocks
From all of the Philcos that have crossed my bench...and they number in the hundreds, I never bothered to count them...out of those that have 110 pF caps in bakelite block shells, the majority were small paper caps. I have encountered a few that had mica caps encapsulated in the tar, though...but as I said, the majority were paper.
As Pete (AI2V) said, dipped micas are excellent replacements for these. And, yes, I replace them as a matter of course in the Philco sets that use them.
0.00011 mf caps in bakelite blocks - by Kestas - 12-09-2014, 05:19 PM
RE: 0.00011 mf caps in bakelite blocks - by morzh - 12-09-2014, 05:55 PM
RE: 0.00011 mf caps in bakelite blocks - by AI2V - 12-09-2014, 06:18 PM
RE: 0.00011 mf caps in bakelite blocks - by Ron Ramirez - 12-09-2014, 10:22 PM
RE: 0.00011 mf caps in bakelite blocks - by morzh - 01-20-2015, 11:25 PM
