what are these Philco's?
Top - 71H
http://www.philcoradio.com/gallery/1932b.htm#x
Bottom - 18X or 118X
http://www.philcoradio.com/gallery/1935b.htm#f
what are these Philco's? - by OldRestorer - 12-09-2014, 11:08 PM
RE: what are these Philco's? - by OldRestorer - 12-09-2014, 11:11 PM
RE: what are these Philco's? - by OldRestorer - 12-09-2014, 11:18 PM
RE: what are these Philco's? - by KCMike - 12-09-2014, 11:31 PM
RE: what are these Philco's? - by tab10672 - 12-10-2014, 12:17 AM
RE: what are these Philco's? - by Ron Ramirez - 12-10-2014, 06:41 AM
RE: what are these Philco's? - by OldRestorer - 12-10-2014, 11:15 AM
RE: what are these Philco's? - by Ron Ramirez - 12-10-2014, 11:56 AM
RE: what are these Philco's? - by OldRestorer - 12-10-2014, 04:41 PM
RE: what are these Philco's? - by AI2V - 12-10-2014, 09:46 PM
RE: what are these Philco's? - by OldRestorer - 12-11-2014, 08:55 AM
RE: what are these Philco's? - by Arran - 12-11-2014, 11:00 PM
RE: what are these Philco's? - by thirtiesradio - 12-12-2014, 03:04 AM
RE: what are these Philco's? - by OldRestorer - 12-12-2014, 10:08 AM
RE: what are these Philco's? - by Arran - 12-13-2014, 12:21 AM
RE: what are these Philco's? - by OldRestorer - 12-19-2014, 09:08 AM
RE: what are these Philco's? - by codefox1 - 12-21-2014, 10:15 AM
There are currently 5934 online users. [Complete List]
» 2 Member(s) | 5932 Guest(s)
