  • 1 Vote(s) - 3 Average
66B original toner colors
Looks real purdy Eric!  Icon_smile
What dd you use for the repaint on the escutcheon?
66B original toner colors - by Eric Adams - 05-08-2014, 10:18 AM
RE: 66B original toner colors - by OldRestorer - 05-08-2014, 12:28 PM
RE: 66B original toner colors - by Bob Andersen - 05-08-2014, 03:57 PM
RE: 66B original toner colors - by Eric Adams - 05-08-2014, 04:17 PM
RE: 66B original toner colors - by Bob Andersen - 05-08-2014, 04:51 PM
RE: 66B original toner colors - by Eric Adams - 05-08-2014, 04:54 PM
RE: 66B original toner colors - by Bob Andersen - 05-08-2014, 05:19 PM
RE: 66B original toner colors - by Eric Adams - 05-08-2014, 05:30 PM
RE: 66B original toner colors - by Eric Adams - 12-10-2014, 05:47 PM
RE: 66B original toner colors - by Capt. Apparatus - 12-10-2014, 06:59 PM
RE: 66B original toner colors - by Eric Adams - 12-10-2014, 07:19 PM
RE: 66B original toner colors - by klondike98 - 12-10-2014, 08:39 PM
RE: 66B original toner colors - by Eric Adams - 12-11-2014, 12:01 AM
