Philco 116 versus 116B
Thanks Chuck,
I am looking forward to finishing this set. I was told this was Philcos top of the line table set. If it was a couple of inches taller it would be a console. It is by far the biggest table set I have owned. I fell into this set as well as my fully restored 38-690! Both for real cheap!! Being a 20's guy I wish I would fall into a couple of AK breadboards as easily!
Thanks Chuck!
Dave
Philco 116 versus 116B - by Dave Slusarczyk - 11-27-2008, 01:29 AM
Re: Philco 116 versus 116B - by Ron Ramirez - 11-27-2008, 08:19 AM
Re: Philco 116 versus 116B - by Dave Slusarczyk - 11-27-2008, 12:24 PM
Re: Philco 116 versus 116B - by Chuck Schwark - 11-28-2008, 12:17 AM
Re: Philco 116 versus 116B - by Dave Slusarczyk - 11-28-2008, 01:07 AM
Re: Philco 116 versus 116B - by BDM - 11-28-2008, 03:35 PM
Re: Philco 116 versus 116B - by etech - 11-30-2008, 11:11 AM
Re: Philco 116 versus 116B - by Ron Ramirez - 11-30-2008, 11:39 AM
Re: Philco 116 versus 116B - by Dave Slusarczyk - 11-30-2008, 02:37 PM
Re: Philco 116 versus 116B - by Ron Ramirez - 11-30-2008, 04:18 PM
Re: Philco 116 versus 116B - by etech - 11-30-2008, 06:54 PM
There are currently 10958 online users. [Complete List]
» 3 Member(s) | 10955 Guest(s)
