Philco 38-15 caps
Good Morning, When I worked on my 38-15 I used the fellowing  12uf-450volts, 10uf-50volts, 4uf  used 4.7uf-450volts, 2uf used 2.7uf-450volts. The 10uf was orginal 25volts the 50 volts replacement was like 4 cents more. I ordered seperate caps from mousser(sp). I did not restuff the old caps just left them in place, put the new ones under the chassie. Yes I am a sinner for not restuffing the old caps!!!!.  I am going to do a seperate post and try and show a picture of one page of my notes with regards to polarity of the 12uf and 10uf. David
Philco 38-15 caps - by Atco - 12-11-2014, 12:12 AM
RE: Philco 38-15 caps - by morzh - 12-11-2014, 11:05 AM
RE: Philco 38-15 caps - by David - 12-11-2014, 11:25 AM
RE: Philco 38-15 caps - by Atco - 12-11-2014, 12:22 PM
RE: Philco 38-15 caps - by klondike98 - 12-11-2014, 11:27 AM
RE: Philco 38-15 caps - by Atco - 12-11-2014, 12:19 PM
RE: Philco 38-15 caps - by David - 12-11-2014, 11:56 AM
RE: Philco 38-15 caps - by morzh - 12-11-2014, 11:58 AM
RE: Philco 38-15 caps - by Atco - 12-11-2014, 12:24 PM
RE: Philco 38-15 caps - by morzh - 12-11-2014, 12:48 PM
RE: Philco 38-15 caps - by David - 12-11-2014, 10:21 PM
RE: Philco 38-15 caps - by morzh - 12-11-2014, 10:50 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
