Philco 38-15 caps
Atco
Only in case you want to do that, this is "a little closer to original" measure that does not require you to go to extraordinary efforts (like some folks here do when they actually replicate old resistors) but still bring the chassis a bit closer to what it used to be like.
In case of quick and dirty approach, old caps may be disconnected and new soldered instead, like backelites can have the leads coming from inside cut, and then the new caps can be soldered to the remaining posts as the holders.
Personally I restuff backelites and lytics.
Philco 38-15 caps - by Atco - 12-11-2014, 12:12 AM
RE: Philco 38-15 caps - by morzh - 12-11-2014, 11:05 AM
RE: Philco 38-15 caps - by David - 12-11-2014, 11:25 AM
RE: Philco 38-15 caps - by Atco - 12-11-2014, 12:22 PM
RE: Philco 38-15 caps - by klondike98 - 12-11-2014, 11:27 AM
RE: Philco 38-15 caps - by Atco - 12-11-2014, 12:19 PM
RE: Philco 38-15 caps - by David - 12-11-2014, 11:56 AM
RE: Philco 38-15 caps - by morzh - 12-11-2014, 11:58 AM
RE: Philco 38-15 caps - by Atco - 12-11-2014, 12:24 PM
RE: Philco 38-15 caps - by morzh - 12-11-2014, 12:48 PM
RE: Philco 38-15 caps - by David - 12-11-2014, 10:21 PM
RE: Philco 38-15 caps - by morzh - 12-11-2014, 10:50 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
