Philco 640 Cabinet Refinishing Chronicles
Wow Geoff. I have followed your progress on this radio off and on . You have done a very nice job on the cabinet and letting everyone know what you used and comparision pictures has helped me learn alot. I have ran into the scratches showing up after using 0000 steel wool and just figured I wasn't doig it right.
RE: Philco 640 Cabinet Refinishing Chronicles - by KCMike - 12-11-2014, 04:47 PM
Users browsing this thread: 45 Guest(s)
Philco 91 Tuning Condenser
There are currently 10142 online users. [Complete List]
» 3 Member(s) | 10139 Guest(s)
