Rebuilding a Philco Tropic 42-730EZ
#55
You might want to try a 330 pf and a 47 pf in parallel, since the original was 375pf, more than the 370 pf you made, if the 350 pair you make doesn't work. Looking at the schematic it seems that might be the way to go. Good luck.
RE: Rebuilding a Philco Tropic 42-730EZ - by sam - 10-15-2014, 04:52 AM
RE: Rebuilding a Philco Tropic 42-730EZ - by sam - 10-19-2014, 05:20 PM
RE: Rebuilding a Philco Tropic 42-730EZ - by mikethedruid - 12-12-2014, 01:16 AM
Users browsing this thread: 22 Guest(s)
Restoring Philco 96
There are currently 7783 online users. [Complete List]
» 2 Member(s) | 7781 Guest(s)
