Light socket repair
I don't believe this is quite what you're asking about but Ron did a pilot lamp rewire in the tech section, maybe part if it will help...
Light socket repair - by thirtiesradio - 12-12-2014, 12:05 PM
RE: Light socket repair - by thirtiesradio - 12-12-2014, 12:06 PM
RE: Light socket repair - by klondike98 - 12-12-2014, 06:41 PM
RE: Light socket repair - by thirtiesradio - 12-14-2014, 02:30 AM
RE: Light socket repair - by thirtiesradio - 12-26-2014, 07:06 PM
RE: Light socket repair - by klondike98 - 12-26-2014, 07:43 PM
RE: Light socket repair - by doug-5er - 01-02-2015, 11:17 PM
RE: Light socket repair - by thirtiesradio - 01-03-2015, 03:19 AM
