what are these Philco's?
Kirk;
  Let him stew on it for a while, then you can get them for $50-75 a piece like they should be, unless he can prove that one set actually was rebuilt with new capacitors and resistors. The model 71, if that's what it is, was a pretty middle of the road set, though it has a six legged cabinet, another version apparently had doors, according to the gallery. The 18/118 was a little better since it had a tuned RF amplifier stage and a class AB power output stage, and a second band, (the 18 had what they would have called the "police band", the 118 had more of a proper shortwave band) though the X cabinet was more mundane, but not ugly. If you look in the gallery there was also a 118B (cathedral), a 118B (shouldered tombstone), a 118H (Highboy) , a 118D (highboy with doors), an earlier version of a 118X, and a 118MX (Moderne inclined sounding board cabinet).
what are these Philco's? - by OldRestorer - 12-09-2014, 11:08 PM
RE: what are these Philco's? - by OldRestorer - 12-09-2014, 11:11 PM
RE: what are these Philco's? - by OldRestorer - 12-09-2014, 11:18 PM
RE: what are these Philco's? - by KCMike - 12-09-2014, 11:31 PM
RE: what are these Philco's? - by tab10672 - 12-10-2014, 12:17 AM
RE: what are these Philco's? - by Ron Ramirez - 12-10-2014, 06:41 AM
RE: what are these Philco's? - by OldRestorer - 12-10-2014, 11:15 AM
RE: what are these Philco's? - by Ron Ramirez - 12-10-2014, 11:56 AM
RE: what are these Philco's? - by OldRestorer - 12-10-2014, 04:41 PM
RE: what are these Philco's? - by AI2V - 12-10-2014, 09:46 PM
RE: what are these Philco's? - by OldRestorer - 12-11-2014, 08:55 AM
RE: what are these Philco's? - by Arran - 12-11-2014, 11:00 PM
RE: what are these Philco's? - by thirtiesradio - 12-12-2014, 03:04 AM
RE: what are these Philco's? - by OldRestorer - 12-12-2014, 10:08 AM
RE: what are these Philco's? - by Arran - 12-13-2014, 12:21 AM
RE: what are these Philco's? - by OldRestorer - 12-19-2014, 09:08 AM
RE: what are these Philco's? - by codefox1 - 12-21-2014, 10:15 AM
There are currently 7553 online users. [Complete List]
» 1 Member(s) | 7552 Guest(s)
