This radio doesn't know the words!
Eric
There have been several threads lately addressing the similar problem.
All I can tell you:
1. Check all tubes for shorted Filament and Cathode (uually output ad Det/1st Audio)
2. Bad grounding - rivets etc
3. Shorted Gnd to chassis if separate, or shorted Filament wire to chassis.
4. Mechanical noise from the power transformer
You have to poke around.
Like, pull tubes one by one, see if it stops and with what tube. Then go from there.
RE: This radio doesn't know the words! - by morzh - 12-14-2014, 12:39 PM
RE: This radio doesn't know the words! - by morzh - 12-14-2014, 04:41 PM
RE: This radio doesn't know the words! - by morzh - 12-14-2014, 08:43 PM
RE: This radio doesn't know the words! - by morzh - 01-04-2015, 08:13 PM
RE: This radio doesn't know the words! - by Arran - 01-04-2015, 10:59 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 9339 online users. [Complete List]
» 2 Member(s) | 9337 Guest(s)
