Dial string aid
There are different types of knots you can make. There is one ( I dont remember the name of it) that you fold the end of the string around and down which looks like the loop then use the loop to tie a knot about an inch down which will hold and stay there, forming a loop. If you dont quite understand what i am explaining You can probably do a search on knots and will find this sort of a knot to make.
Dial string aid - by Art Hoch - 12-15-2014, 06:38 PM
RE: Dial string aid - by Warren - 12-15-2014, 06:54 PM
RE: Dial string aid - by Art Hoch - 12-15-2014, 09:15 PM
RE: Dial string aid - by Eric Adams - 12-15-2014, 10:06 PM
RE: Dial string aid - by klondike98 - 12-15-2014, 11:54 PM
RE: Dial string aid - by Arran - 12-16-2014, 01:00 AM
RE: Dial string aid - by Warren - 12-16-2014, 04:24 PM
RE: Dial string aid - by Arran - 12-17-2014, 04:26 AM
RE: Dial string aid - by Art Hoch - 12-16-2014, 05:05 PM
RE: Dial string aid - by mikethedruid - 12-18-2014, 04:06 AM
There are currently 7607 online users. [Complete List]
» 1 Member(s) | 7606 Guest(s)
