Philco 116 versus 116B
Dave
Philco changed the AVC circuit in later production of Model 116. That change is discussed here:
http://www.philcoradio.com/tech/116.htm
Philco 116 versus 116B - by Dave Slusarczyk - 11-27-2008, 01:29 AM
Re: Philco 116 versus 116B - by Ron Ramirez - 11-27-2008, 08:19 AM
Re: Philco 116 versus 116B - by Dave Slusarczyk - 11-27-2008, 12:24 PM
Re: Philco 116 versus 116B - by Chuck Schwark - 11-28-2008, 12:17 AM
Re: Philco 116 versus 116B - by Dave Slusarczyk - 11-28-2008, 01:07 AM
Re: Philco 116 versus 116B - by BDM - 11-28-2008, 03:35 PM
Re: Philco 116 versus 116B - by etech - 11-30-2008, 11:11 AM
Re: Philco 116 versus 116B - by Ron Ramirez - 11-30-2008, 11:39 AM
Re: Philco 116 versus 116B - by Dave Slusarczyk - 11-30-2008, 02:37 PM
Re: Philco 116 versus 116B - by Ron Ramirez - 11-30-2008, 04:18 PM
Re: Philco 116 versus 116B - by etech - 11-30-2008, 06:54 PM
There are currently 7031 online users. [Complete List]
» 1 Member(s) | 7030 Guest(s)
