Philco 116 versus 116B
Quote:As far as your desire for a 38-690. I may be selling mine. Just not what I collect. Space is a commodity in my shop. I will see---
I might even have to drive down there and pick it up. Icon_smile
Quote:d**n the luck, Ed, you beat me to it.
I too would like for Santa to leave a 37-690 or 38-690 under my tree...
I think a lot of folks would! Icon_biggrin
Ed
Philco 116 versus 116B - by Dave Slusarczyk - 11-27-2008, 01:29 AM
Re: Philco 116 versus 116B - by Ron Ramirez - 11-27-2008, 08:19 AM
Re: Philco 116 versus 116B - by Dave Slusarczyk - 11-27-2008, 12:24 PM
Re: Philco 116 versus 116B - by Chuck Schwark - 11-28-2008, 12:17 AM
Re: Philco 116 versus 116B - by Dave Slusarczyk - 11-28-2008, 01:07 AM
Re: Philco 116 versus 116B - by BDM - 11-28-2008, 03:35 PM
Re: Philco 116 versus 116B - by etech - 11-30-2008, 11:11 AM
Re: Philco 116 versus 116B - by Ron Ramirez - 11-30-2008, 11:39 AM
Re: Philco 116 versus 116B - by Dave Slusarczyk - 11-30-2008, 02:37 PM
Re: Philco 116 versus 116B - by Ron Ramirez - 11-30-2008, 04:18 PM
Re: Philco 116 versus 116B - by etech - 11-30-2008, 06:54 PM
There are currently 10538 online users. [Complete List]
» 3 Member(s) | 10535 Guest(s)
