Not very happy with the photofinish
Definitely an possibility Eric.
  I need one for my 84 but won't get that till I get moved in to the new house. I will be following the direction better.
I am hoping I will not have the issue again.
Like I said, He is definitely an asset and I sure need that new photofinish for this poor baby.
RE: Not very happy with the photofinish - by OldRestorer - 12-17-2014, 11:34 AM
RE: Not very happy with the photofinish - by sam - 12-18-2014, 12:23 AM
