Model 14 Bakelite block question
Hi Mike, It looks like there was a replacement in the block capacitor Index.the 3615 BM was replaced with a 3615ODG which is 2 (two) .05 caps.
  http://www.antiqueradios.com/philcorestorer/page10.html
http://www.antiqueradios.com/philcorestorer/page9.html
Hows that dial coming along?
Model 14 Bakelite block question - by k9uw - 12-18-2014, 05:25 PM
RE: Model 14 Bakelite block question - by doug-5er - 12-18-2014, 05:58 PM
RE: Model 14 Bakelite block question - by k9uw - 12-18-2014, 07:18 PM
