Just got a 116B
I don't think it was over priced. You don't see the 116's often. The fact that it plays is always a big plus even if you want to go over the last persons cap job. I haven't bought a 116 as of yet, but I do have a 16B and the performance/sound is awesome. The 10" speaker Philco put in these sets have a deep, full sound.
Just got a 116B - by Jayce - 12-18-2014, 06:01 PM
RE: Just got a 116B - by mikethedruid - 12-18-2014, 06:37 PM
RE: Just got a 116B - by Geoff - 12-18-2014, 06:40 PM
RE: Just got a 116B - by thirtiesradio - 12-19-2014, 12:51 AM
RE: Just got a 116B - by Arran - 12-19-2014, 01:38 AM
RE: Just got a 116B - by Jayce - 12-19-2014, 01:49 AM
RE: Just got a 116B - by thirtiesradio - 12-19-2014, 02:23 AM
RE: Just got a 116B - by GarySP - 12-19-2014, 08:56 AM
RE: Just got a 116B - by Jayce - 12-19-2014, 12:28 PM
RE: Just got a 116B - by Eliot Ness - 12-19-2014, 12:40 PM
There are currently 5187 online users. [Complete List]
» 5 Member(s) | 5182 Guest(s)
AvatarAvatarAvatarAvatar
