Philco 90 later version
http://philcoradio.com/phorum/showthread...light=tone
This is a 90 tone control restoration by myself.
Philco 90 later version - by murf - 12-14-2014, 12:07 AM
RE: Philco 90 later version - by Ron Ramirez - 12-14-2014, 10:05 AM
RE: Philco 90 later version - by murf - 12-14-2014, 10:17 AM
RE: Philco 90 later version - by murf - 12-15-2014, 09:45 PM
RE: Philco 90 later version - by KCMike - 12-15-2014, 11:27 PM
RE: Philco 90 later version - by Steve Davis - 12-15-2014, 11:50 PM
RE: Philco 90 later version - by murf - 12-16-2014, 11:10 AM
RE: Philco 90 later version - by morzh - 12-16-2014, 11:38 PM
RE: Philco 90 later version - by murf - 12-17-2014, 11:22 PM
RE: Philco 90 later version - by morzh - 12-18-2014, 12:08 AM
RE: Philco 90 later version - by Steve Davis - 12-18-2014, 12:38 PM
RE: Philco 90 later version - by murf - 12-18-2014, 10:21 PM
RE: Philco 90 later version - by morzh - 12-19-2014, 04:13 PM
RE: Philco 90 later version - by morzh - 12-19-2014, 04:18 PM
RE: Philco 90 later version - by morzh - 12-20-2014, 12:32 AM
RE: Philco 90 later version - by murf - 12-20-2014, 01:16 PM
RE: Philco 90 later version - by murf - 01-13-2015, 11:19 AM
RE: Philco 90 later version - by murf - 01-14-2015, 11:49 PM
RE: Philco 90 later version - by morzh - 01-15-2015, 12:09 AM
RE: Philco 90 later version - by Ron Ramirez - 01-15-2015, 07:12 AM
RE: Philco 90 later version - by murf - 01-15-2015, 08:48 PM
RE: Philco 90 later version - by murf - 02-01-2015, 03:32 PM
RE: Philco 90 later version - by klondike98 - 02-01-2015, 04:03 PM
RE: Philco 90 later version - by murf - 02-01-2015, 04:14 PM
RE: Philco 90 later version - by klondike98 - 02-01-2015, 04:17 PM
RE: Philco 90 later version - by murf - 02-02-2015, 11:10 PM
RE: Philco 90 later version - by morzh - 02-02-2015, 11:39 PM
RE: Philco 90 later version - by murf - 05-07-2015, 05:42 PM
RE: Philco 90 later version - by klondike98 - 05-07-2015, 05:53 PM
RE: Philco 90 later version - by morzh - 05-07-2015, 08:23 PM
RE: Philco 90 later version - by klondike98 - 05-07-2015, 08:39 PM
There are currently 6011 online users. [Complete List]
» 1 Member(s) | 6010 Guest(s)
