Model 50, did I jump too fast?
There is a Model 52 chassis on our favorite online auction site right now. It will give you an idea of what the Model 50 chassis should look like.
http://cgi.ebay.com/6588590735
Model 50 is TRF, while Models 51 and 52 (identical chassis) are superhets. On top, the chassis look nearly identical.
(edit) Just found the Model 50 you won. Cabinet looks nice. I see yours is missing the tube shield as well as the five tubes.
Model 50, did I jump too fast? - by n9vu - 12-18-2005, 01:11 AM
[No subject] - by Ron Ramirez - 12-19-2005, 01:17 AM
[No subject] - by n9vu - 12-19-2005, 11:04 PM
[No subject] - by n9vu - 12-19-2005, 11:06 PM
[No subject] - by Ron Ramirez - 12-20-2005, 09:40 PM
[No subject] - by n9vu - 12-25-2005, 03:36 AM
[No subject] - by Ron Ramirez - 12-25-2005, 11:30 AM
[No subject] - by n9vu - 12-28-2005, 12:33 AM
Sorry to hear it.... - by zenith82 - 12-29-2005, 11:37 PM
Re: Sorry to hear it.... - by n9vu - 01-06-2006, 10:28 PM
[No subject] - by Ron Ramirez - 01-06-2006, 10:57 PM
[No subject] - by n9vu - 01-07-2006, 01:38 PM
Philco 91 Tuning Condenser
There are currently 9508 online users. [Complete List]
» 3 Member(s) | 9505 Guest(s)
