Philco Cda 44-121 Ident & Info Required
Welcome to the Phorum!!
Ron has a listing of some Canadian models and their US equivalent here.  It doesn't, however, show an equivalent for either the 44AX (1941) or 44AXD (1942) but both were 11 tube chassis.  It may be a bit before Ron is back online but there are some other folks here with experience in Canadian sets who will likely chime in.
Philco Cda 44-121 Ident & Info Required - by CanoeBear - 12-19-2014, 02:35 PM
RE: Philco Cda 44-121 Ident & Info Required - by klondike98 - 12-19-2014, 05:30 PM
There are currently 5519 online users. [Complete List]
» 5 Member(s) | 5514 Guest(s)
AvatarAvatarAvatarAvatar
