Philco 90 later version
Murf
I ain't sure no more but the component you are showing looks an awful lot like a volume regulator potentiometer, not the tone switch.
Now if it is the case (it is part # 20) you have one end grounded, the middle one goes to 27 tube DET AMP's grid, and the third pin (you are holding the wire from it) goes to where caps 18 and 19 connect together.
Philco 90 later version - by murf - 12-14-2014, 12:07 AM
RE: Philco 90 later version - by Ron Ramirez - 12-14-2014, 10:05 AM
RE: Philco 90 later version - by murf - 12-14-2014, 10:17 AM
RE: Philco 90 later version - by murf - 12-15-2014, 09:45 PM
RE: Philco 90 later version - by KCMike - 12-15-2014, 11:27 PM
RE: Philco 90 later version - by Steve Davis - 12-15-2014, 11:50 PM
RE: Philco 90 later version - by murf - 12-16-2014, 11:10 AM
RE: Philco 90 later version - by morzh - 12-16-2014, 11:38 PM
RE: Philco 90 later version - by murf - 12-17-2014, 11:22 PM
RE: Philco 90 later version - by morzh - 12-18-2014, 12:08 AM
RE: Philco 90 later version - by Steve Davis - 12-18-2014, 12:38 PM
RE: Philco 90 later version - by murf - 12-18-2014, 10:21 PM
RE: Philco 90 later version - by morzh - 12-19-2014, 04:13 PM
RE: Philco 90 later version - by morzh - 12-19-2014, 04:18 PM
RE: Philco 90 later version - by morzh - 12-20-2014, 12:32 AM
RE: Philco 90 later version - by murf - 12-20-2014, 01:16 PM
RE: Philco 90 later version - by murf - 01-13-2015, 11:19 AM
RE: Philco 90 later version - by murf - 01-14-2015, 11:49 PM
RE: Philco 90 later version - by morzh - 01-15-2015, 12:09 AM
RE: Philco 90 later version - by Ron Ramirez - 01-15-2015, 07:12 AM
RE: Philco 90 later version - by murf - 01-15-2015, 08:48 PM
RE: Philco 90 later version - by murf - 02-01-2015, 03:32 PM
RE: Philco 90 later version - by klondike98 - 02-01-2015, 04:03 PM
RE: Philco 90 later version - by murf - 02-01-2015, 04:14 PM
RE: Philco 90 later version - by klondike98 - 02-01-2015, 04:17 PM
RE: Philco 90 later version - by murf - 02-02-2015, 11:10 PM
RE: Philco 90 later version - by morzh - 02-02-2015, 11:39 PM
RE: Philco 90 later version - by murf - 05-07-2015, 05:42 PM
RE: Philco 90 later version - by klondike98 - 05-07-2015, 05:53 PM
RE: Philco 90 later version - by morzh - 05-07-2015, 08:23 PM
RE: Philco 90 later version - by klondike98 - 05-07-2015, 08:39 PM
There are currently 6175 online users. [Complete List]
» 3 Member(s) | 6172 Guest(s)
