38-5 volume problem
I wonder why the volume was bouncing....unless it was a phaseshift created by the cap since the triode is part of the AVC which is a neg. feedback so it got to oscillate....
38-5 volume problem - by r8i0 - 12-14-2014, 08:46 PM
RE: 38-5 volume problem - by jerryhawthorne - 12-15-2014, 01:10 AM
RE: 38-5 volume problem - by Arran - 12-15-2014, 01:38 AM
RE: 38-5 volume problem - by r8i0 - 12-15-2014, 09:45 AM
RE: 38-5 volume problem - by r8i0 - 12-17-2014, 02:21 PM
RE: 38-5 volume problem - by r8i0 - 12-17-2014, 02:24 PM
RE: 38-5 volume problem - by klondike98 - 12-17-2014, 02:36 PM
RE: 38-5 volume problem - by r8i0 - 12-17-2014, 06:25 PM
RE: 38-5 volume problem - by KCMike - 12-17-2014, 07:07 PM
RE: 38-5 volume problem - by r8i0 - 12-17-2014, 07:38 PM
RE: 38-5 volume problem - by Arran - 12-19-2014, 02:27 AM
RE: 38-5 volume problem - by KCMike - 12-17-2014, 07:41 PM
RE: 38-5 volume problem - by jerryhawthorne - 12-18-2014, 04:02 PM
RE: 38-5 volume problem - by r8i0 - 12-18-2014, 09:19 PM
RE: 38-5 volume problem - by klondike98 - 12-18-2014, 11:05 PM
RE: 38-5 volume problem - by r8i0 - 12-18-2014, 11:33 PM
RE: 38-5 volume problem - by r8i0 - 12-21-2014, 02:25 PM
RE: 38-5 volume problem - by klondike98 - 12-21-2014, 02:34 PM
RE: 38-5 volume problem - by morzh - 12-21-2014, 04:46 PM
Restoring Philco 96
There are currently 5401 online users. [Complete List]
» 4 Member(s) | 5397 Guest(s)
AvatarAvatarAvatarAvatar
