Next project - Philco Tropic 41-758EZ
(12-20-2014, 11:40 PM)Ron Ramirez Wrote:  ...These are the warm white LED lamps with miniature bayonet bases and flexible leads that I have mentioned before.
http://www.pinballlife.com/index.php?p=product&id=3108
Thanks for that link Ron.  I have ordered LED bulbs from PinballLife before but they didn't have the version with the flexible leads back then, those look pretty versatile.   The extra illumination those provide for an edge lit dial makes a lot of difference.  I just placed a few on order as well as some of the following:
http://www.pinballlife.com/index.php?p=product&id=3105
http://www.pinballlife.com/index.php?p=product&id=3211
All in warm white....if they provide some brighter illumination along with less chance of heat burning a dial face then it is a win-win.
RE: Next project - Philco Tropic 41-758EZ - by Eliot Ness - 12-22-2014, 10:41 AM
Users browsing this thread: 13 Guest(s)
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
There are currently 3477 online users. [Complete List]
» 2 Member(s) | 3475 Guest(s)
