Next project - Philco Tropic 41-758EZ
Gary
Thanks! I don't think anyone currently making LED substitutes are making anything for 2.5VAC applications. I also have not seen any miniature screw bases in these lamps; Pinball Life only has miniature bayonet, made for 6V DC or 6V AC/DC.
If you are really handy with miniature parts, you could make your own. It would take a large frosted LED lamp, a diode to rectify the AC to DC, a small resistor to drop the 2.5 VAC voltage to 2.2V, and a miniature screw base from an old lamp. It's not something I want to try at the present time, though.
RE: Next project - Philco Tropic 41-758EZ - by Ron Ramirez - 12-22-2014, 12:57 PM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 3504 online users. [Complete List]
» 1 Member(s) | 3503 Guest(s)
