Philco radio from 1971 Ford F100
Check your antenna, you got a VOM, check for continuity , unplug the antenna, open mast to ground, center plug to mast continuity, shield to ground ,continuity center plug to shield open, years ago I repaired a Pontiac Astra radio, complaint was no stations unless you where by the radio transmiter found a broken antenna coil, as junky as thing where in the 70's for the most part, the radios out lasted the car! Back then I drove a 1953 Chevrolet ,a real car! ,BILL
Philco radio from 1971 Ford F100 - by Guest - 12-02-2008, 11:17 PM
Re: Philco radio from 1971 Ford F100 - by exray - 12-02-2008, 11:50 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-03-2008, 01:26 AM
Re: Philco radio from 1971 Ford F100 - by BILL - 12-03-2008, 03:59 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-03-2008, 10:30 PM
Re: Philco radio from 1971 Ford F100 - by BILL - 12-04-2008, 11:16 AM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-04-2008, 03:09 PM
Re: Philco radio from 1971 Ford F100 - by BILL - 12-04-2008, 07:51 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-05-2008, 01:21 PM
Re: Philco radio from 1971 Ford F100 - by BILL - 12-05-2008, 03:53 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-05-2008, 11:24 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 10-30-2009, 01:40 PM
There are currently 4615 online users. [Complete List]
» 1 Member(s) | 4614 Guest(s)
