Here we go with a Brand Z 9-S-262
When replacing the motor drive belt I always leave a little slack in it. If tight they won't run smooth or at all. I bought a couple radios that the motor drive worked great for a couple seconds, then it slowed down or stopped. A looser belt replacement always fixed the problem.
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-22-2014, 03:36 PM
RE: Here we go with a Brand Z 9-S-262 - by murf - 12-24-2014, 12:16 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-22-2014, 03:59 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-22-2014, 04:04 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-22-2014, 09:38 PM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 12-23-2014, 01:04 AM
RE: Here we go with a Brand Z 9-S-262 - by thirtiesradio - 12-23-2014, 04:28 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-23-2014, 06:22 PM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-23-2014, 06:32 PM
RE: Here we go with a Brand Z 9-S-262 - by sam - 12-24-2014, 05:27 AM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-24-2014, 11:25 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-24-2014, 06:12 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-24-2014, 11:21 PM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-25-2014, 12:16 AM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-25-2014, 12:39 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-25-2014, 12:21 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-25-2014, 06:03 PM
RE: Here we go with a Brand Z 9-S-262 - by sam - 12-25-2014, 01:59 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-25-2014, 02:57 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-25-2014, 03:18 AM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 12-26-2014, 12:00 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 12-25-2014, 03:16 AM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-28-2014, 10:14 PM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-01-2015, 11:07 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 12-30-2014, 06:34 PM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 12-31-2014, 04:03 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-01-2015, 02:43 AM
RE: Here we go with a Brand Z 9-S-262 - by murf - 01-01-2015, 09:10 PM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-04-2015, 02:19 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-03-2015, 10:22 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-03-2015, 10:45 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-04-2015, 01:06 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-04-2015, 03:50 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-04-2015, 08:16 PM
RE: Here we go with a Brand Z 9-S-262 - by GarySP - 01-04-2015, 10:37 PM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-05-2015, 02:51 PM
RE: Here we go with a Brand Z 9-S-262 - by sam - 01-05-2015, 11:41 PM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-06-2015, 12:25 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-06-2015, 09:56 PM
RE: Here we go with a Brand Z 9-S-262 - by sam - 01-07-2015, 08:29 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-08-2015, 12:40 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-08-2015, 01:52 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-08-2015, 02:03 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-08-2015, 03:30 PM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-09-2015, 11:07 AM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-08-2015, 11:31 PM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-09-2015, 05:10 PM
RE: Here we go with a Brand Z 9-S-262 - by sam - 01-10-2015, 03:21 AM
RE: Here we go with a Brand Z 9-S-262 - by Geoff - 01-10-2015, 03:17 PM
RE: Here we go with a Brand Z 9-S-262 - by sam - 01-10-2015, 07:10 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-10-2015, 10:52 PM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-15-2015, 10:28 PM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-16-2015, 02:34 AM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-18-2015, 02:07 AM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-19-2015, 12:29 AM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-16-2015, 09:46 AM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-17-2015, 02:07 AM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-17-2015, 01:00 PM
RE: Here we go with a Brand Z 9-S-262 - by Arran - 01-18-2015, 01:53 AM
RE: Here we go with a Brand Z 9-S-262 - by morzh - 01-18-2015, 12:35 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6252 online users. [Complete List]
» 1 Member(s) | 6251 Guest(s)
